Rodd
Recruit
My 98 suburban was having intermittent starting issues where it would click then nothing. This was before I replaced the IP. When I did the IP I cleaned all the grounds. When I was having the problems I would take my screwdriver and bump it at the starter and then start it up with the key. It has started happening again. I did isolate one of the starter grounds located on one of the lower intake studs on the passenger side when I was putting it back together. It wouldn't start with the key or the screwdriver till I tightened it down really good. My question is, is that the only ground for the starter or are there more?
