Governed RPM of the 6.5 TD - DB2.
WarWagon
Well it hits on 7 of 8...
AZ
Double check me on this. Governed RPM of the 6.5 TD is this the red or orange area on the tach? I recall red is no load compression braking RPM and orange is full load/throttle lower RPM.
So the floored RPM in neutral should be 3500 'orange' or 4000 'red' RPM?
What RPM are you DB2 guys getting when you floor it in neutral? (This is safe as the emissions tests require you to floor it and hold it for smoke tests.)
