Got the Delphi N/A's reset today
Pruittx2
Been around a bit
Lake Odessa, Mi
Well I went down to my local Injectory shop, He's a cool older~ish fella that really knew his chit. He was suprised I had a set of the Delphi N/A injectors, for $115. He does Tons of stuff for the Mi Nat Guard, and seen the label and new Exactly what I had. We checked them first, to find anywhere from 130Bar,,,, to 145Bar., Total of 45 mins, we did all 8 and he let me back in the shop, for a how too. Sorry I didn't take my camera. Now I have them all set to 2200Psi with in 20-30Psi, of each other
For you rebuilders, he said when I ask about the springs settling in after a few heats cycles, He seemed to thing about 40-80 psi could be expected. But if your rebuilding a set of them,, to flip the spring upside down for the rebuild. As that end of the spring he say's " Don't get used like the other side."
With an install kit, and resetting the pop's,, I left $32.50 and $48.00 lighter.
New Delphi's 2200Psi,,, Ready for the install, total of $195.50
New Delphi's 2200Psi,,, Ready for the install, total of $195.50 [/FONT][/QUOTE]
PRICELESS!
Good job, Pruitt!
Sounds like you got a GREAT deal and made a knowledgeable friend at the same time ... Nice!
It's amazing how sloppy the factories let these, and other brands also,go. After seeing it first hand i'd never just put a set of injectors in. They all will be tested and adjusted. From what I've heard bosch is just as sloppy.
Should run real strong, and smoother on the highway.
People that purchase new stock ones are likely to get them like this. Although, if you purchase rebuilt or "marine" or "high output" its likely that the rebuilders are better than the factory and most people get a matched set from vendors that sell rebuilds. At least I would hope so. Or they are just more precise with the setting of the pressures.
I been saying that off and on for a while allready on these injector ? treads,i'm glad you are now convinced too.I dont feel so alone no more:smile5:
