Mad Maxx
See, what had happened was...
Ok, so prob. none of you have ever Heard of this, but it's Made by a Company Called "Catz" and it is the "Zeta" System. They are Located in Japan, and their Parts are VERY Difficult to come by here in the States. Aaaand they stopped Making this System back around '03, so Good Luck Finding one.
It Looks just like an HID Ballast, it has an Input and and Output Side. You Plug your Factory Bulb Plug into the Input Side, then on the Output Side, you Connect it to the Bulb. Inside the Box is where the Magic Happens. It takes your Factory Voltage, whatever it may be Depending on the Condition of your Electrical System, and Steps it Up to around 15.2v You can See the "Effect" happen because when you first Turn On the Lights, they are at Factory Voltage, then "Zeta Boost" happens, and you can actually See them get Brighter, so you know the System is Working.
...now why do I say it's Better than HID's?
I've Modded 9011 HIR's to Fit my Low Beams. 65w of Power, with HIR Technology, running at about 15.2v...after a few Minutes, they are just as Bright as HID, with no real Warmup Time, I can Flash them all I want and not have to Worry about Blowing a Bulb or Ballast, aaaand, my Beam Pattern stays the same. Because if you didn't know, when you put HID's in an 03-07 Silverado, the Beam Pattern actually Tightens Up, and you don't get as much Spread with the HID's as you do with Halogens.
