hereismylife
formerly j k auto
Found one with 144 k. Runs fine with alittle stumble from idle to 3/4 throttle. Injectors seems to be putting out to much full at 3500 rpm...cold fuel burns your eyes....vehicle has exhaust leaks .....
Anyhow started removing stuff. Only problem is I broke the shields off the glow plugs on pass side.....
