Crankme69
My truck is nearing the 200K mark on the clock. I purchased the truck with 193K on it. It's winter here in ILL & I would like to dump the DYNO 15/40 out & go with SYN 15/40 to help ease the load on the starter during the winter.
I have no history on the motor other then what I have gathered in the last 4K miles. It has used 1 qt of oil at 3K on the dyno change currently. I checked the motor for blow bye it almost does not exist at idle or 2k rpms, the truck is in excellent shape for the miles, it was owned by a Firechief or at least that is what I was informed and appears mechanically & cosmetically to have been very well cared for.
I'm just a little old school here, this motor is a S vin with an EGR valve & as far as I know is virgin stock other then a 3" exhaust & cat delete.
My real concern is how much grab that friggin EGR valve has recycled & piled up in the motor & what the effect of the high detergent SYN is going to have, leaks or oil consumption possibly???
What would you do & why? Am I just an old fool & worried for nothing?
Should I drop the filter & top it off with syn for the first go around to maybe ease it on to syn? I really don't like mixing & matching oil brands or types due to the additive packages may not play well together...
Your thoughts or experiences would be appreciated.
TIA,
69
TIA,
69
