Going SAS w/FORD high pinion king pin DANA 60 of the 79 variety
FellowTraveler
Nature Coast
Was going to do a 2.5" suspension lift & drop the IFS diff but instead decided to go SAS instead. I'll be going low (minium lift) as I can on the install using ORD kit.
Now you NEED my np241. The internal slip yoke design on the np246 is not reccomended for a solid front axle as there just isn't enough splines in there, or anyway to grease them. I think 4 inches is just about the lowest you can go with a sfa on one of these trucks.
YEP, knew that and will get together w/you soon for your t-case, I found a complete shifter w/interior trim for the NP261 I'll mod that to the N241.
