Crankme69
I just got the cable and was able to connect to my 1995. The truck runs good, but I am leery to do anything that may leave me without it. I do not have the long wrench that if I read the postings correctly I will need if I must move the IP. Based on what I have read searching here it appears my timing is advanced, but again I'm skeeerd to try anything with the software like like the TDC time set or TDC learn if doing that may end up leaving me without my truck.
So is there a risk doing the TDC learn & offset? Should I just leave it alone...?
Here is my snapshot from GMTDScan.
Snapshot created 2/26/2010 3:07:21 PM
__________________________________________________________________
ENGINE SENSORS
Engine run time: 00:56:38
Boost pressure (MAP): 14.2 PSI
Desired EGR: 11.68 PSI
Desired idle: 562 RPM
EGR pressure: 14.36 PSI
EGR duty cycle: 99.6 %
Engine coolant temp: 187.3 F°
Engine speed: 562 RPM
Glow plug relay feedback: 0 Volts
Glow plug voltage: 0.2 Volts
Ignition voltage: 13.5 Volts
Wastegate duty cycle: 72.3 %
INFORMATION SENSORS
PCM Calibration ID: 7135
Current DTCs: 0
Accel. ped. pos. 1: 0.59 Volts
Accel. ped. pos. 2: 4.45 Volts
Accel. ped. pos. 3: 4.08 Volts
Barometric pressure (BARO): 13.45 PSI
Battery voltage: 13.7 Volts
Fuel temperature: 86.8 F°
Intake air temp: 90.9 F°
Throttle position: 0 %
Turbo boost (Calculated): 0.75 PSI
Voltage reference sensor: 1.3 Volts
INJECTION PUMP SENSORS
Actual injection pump timing: 28.07 Deg °
Cam reference missed: 0 Counts
Crank reference missed: 0 Counts
Fuel calibration: 120 Counts
Fuel rate: 7.81 mm³
Fuel rate - Cruise: 0 mm³
Fuel rate - Idle: 8.12 mm³
Fuel rate - Maximum transient: 42.5 mm³
Fuel rate - Throttle requested: 0 mm³
Injection pulse width: 1.67 ms
Injection timing - Measured: 6.3 Deg °
Injection timing - Desired: 6.7 Deg °
TDC offset: 0.35 Deg °
TRANSMISSION SENSORS
3-2 PWM solenoid duty cycle: 0 %
Cruise target speed: 0 MPH
Cruise speed error: 0 MPH
Current gear of transmission: 1 Gear
Current torque signal pressure: 25 PSI
Current transmission ratio: 1:4 Ratio
Error between desired and actual shift times for latest 1-2 upshift: 0 Sec
Error between desired and actual shift times for latest 2-3 upshift: 6.3 Sec
Force motor (PCS) - Duty cycle: 44.5 %
Force motor (PCS) - Feedback current: 0.84 Amps
Force motor (PCS) - Reference current: 0.82 Amps
Time of latest 1-2 upshift: 0.3 Sec
Time of latest 2-3 upshift: 0.4 Sec
TCC PWM solenoid duty cycle: 0 %
TCC slippage: 26 RPM
Transmission input speed: 543 RPM
Transmission output speed: 0 RPM
Transmission temperature: 150.4 F°
Turbine speed: 543 RPM
Vehicle speed: 0 MPH
STATUS FLAGS
Shift lever:
Park/Neutral
Cruise control:
Cruise Off condition
TCC mode word 1:
TCC is being forced off
TCC enable solenoid valid
Low threshold for COPETCC selected
Use hyst. for vehicle speed
TCC is in release mode, slipping
TCC is in locked-adjust mode
TCC is being applied
Negative slip recently prevents apply
TCC mode word 2:
TCC PWM is on
Perform release
Perform apply
Min. threshold occurred
• TCC Bus. is valid
NDT occurs
Delay is in progress
Min. throttle occured
IOD port A:
Glow plug relay - Closed/Open
• Stepper motor inhibit - Run/Inhibit
Service Throttle Lamp - On/Off
• EGR vent enable - On/Off
• Shift A - On/Off
Shift B - On/Off
TCC enable - On/Off (4L60E only)
• Force Motor enable - On/Off
IOD SOD status register:
Coolant temp. pullup select - On/Off
Trans. temp. pullup select - On/Off
Fuel calibration temp. select - On/Off
Check Engine Lamp - On/Off
PWM1 - Reset/Normal
PWM2 - Reset/Normal
PWM3 - Reset/Normal
PWM4 - Reset/Normal
System status word:
FM shut off due to low battery
Force Motor pulse in progress
• Power is On/Off
COP2 is being serviced
Delco instrumentation PROM
• Powertrain is in motion
Discrete flags:
Brake - On/Off
A/C Compressor - Engaged/Disengaged
Power enrichment - Active/Inactive
Kickdown pattern - Active/Inactive
Four-Wheel Drive Low - Active/Inactive
Cruise low - Active/Inactive
Diagnostic - Requested/Not requested
ENGINE SENSORS
INFORMATION SENSORS
Current DTCs: 0
Fuel rate: 7.81 mm³
STATUS FLAGS
Shift lever:
Park/Neutral
Cruise control:
TCC mode word 1:
TCC mode word 2:
TCC PWM is on
Perform release
Perform apply
• TCC Bus. is valid
NDT occurs
IOD port A:
• Shift A - On/Off
Shift B - On/Off
PWM1 - Reset/Normal
PWM2 - Reset/Normal
PWM3 - Reset/Normal
PWM4 - Reset/Normal
System status word:
• Power is On/Off
Discrete flags:
Brake - On/Off
