ENGINE SENSORS
Engine run time: 00:00:00
Boost pressure (MAP): 28.4 PSI
Desired EGR: 10.59 PSI
Desired idle: 2325 RPM
EGR pressure: 2.61 PSI
EGR duty cycle: 60.5 %
Engine coolant temp: 127.6 F°
Engine speed: 19 RPM
Glow plug relay feedback: 0 Volts
Glow plug voltage: 5.1 Volts
Ignition voltage: 24.4 Volts
Wastegate duty cycle: 71.9 %
__________________________________________________________________
INFORMATION SENSORS
PCM Calibration ID: 0
Current DTCs: 42
Accel. ped. pos. 1: 0 Volts
Accel. ped. pos. 2: 5.02 Volts
Accel. ped. pos. 3: 5 Volts
Barometric pressure (BARO): 8.69 PSI
Battery voltage: 2.5 Volts
Fuel temperature: 134.2 F°
Intake air temp: 304.3 F°
Throttle position: 0 %
Turbo boost (Calculated): 19.72 PSI
Voltage reference sensor: 0.8 Volts
INJECTION PUMP SENSORS
Actual injection pump timing: 604.12 Deg °
Cam reference missed: 210 Counts
Crank reference missed: 134 Counts
Fuel calibration: 64 Counts
Fuel rate: 9.69 mm³
Fuel rate - Cruise: 0 mm³
Fuel rate - Idle: 0 mm³
Fuel rate - Maximum transient: 41.88 mm³
Fuel rate - Throttle requested: 22.88 mm³
Injection pulse width: 185.04 ms
Injection timing - Measured: 0 Deg °
Injection timing - Desired: 0 Deg °
TDC offset: 36.96 Deg °
INFORMATION SENSORS
Current DTCs: 42
Fuel rate: 9.69 mm³
