knh208
When I replaced my injectors a few weeks ago, I started checking my turbo for play to see what condition it is in. I was able to check more closely today with a better set of feeler gages. There is very little axial play, but a decent amount of radial play. With shaft pushed away, I have 0.016" between the wheel and the housing. With the shaft held close, I have 0.0025" between the wheel and the housing . That tells me that I have 0.014" radial play (±0.007") and pretty tight clearance.
Does anyone know what the service limits are for the GM-X turbos? How do they measure when new? Should I be concerned? How close should I let this get? :???:
Obviously, I know that the worst case result of 0.000" clearance would be catastrophic failure of turbo and engine. The truck has 305,000 kms (189,000 miles) on it now. I plan on driving it until a major failure occurs. Given my recent tune up efforts, I hope that means for a couple years. I'm quite happy to enjoy my truck that is paid for, but at the same time, if spending a little is what it takes to keep it moving another year, so be it. :agreed:
Cheers,
Kevin :thumbsup:
Cheers,
Kevin :thumbsup:
