jmiller
Recruit
So we had some rubbing of a glow plug wire that eventually caused a short
to the frame on one of the glow plugs. This severely damaged the glow plug wiring harness.
I can't quite understand why the left side and right side of the glow plug
harness are so different and don't seem to match the wiring diagram in the
service manual or general guideline for fusable link sizing in a wiring harness?
So in looking at the wiring diagram in the manual and the glow plug harness, I be
became concerned with differences. The wiring diagram shows each bank on separate
14 gauge fusable links and 10 gauge wire to each glow plug and a 18 gauge fusable link for each glow plug.
The wiring harness has major differences between the left and right bank.
The left bank glow plug has a 14 gauge fusable link. Two 12 gauge wires to each pair of
cylinders 1-3 and 5-7. Then 18 gauge fusable links to each glow plug.
The right bank has the 14 gauge fusable link, like the left side. Then the 18 gauge
fusable links for each cylinder connected to separate 16 or 18 gauge wires to each glow plug.
Other than the right side wires having Teflon insulation for heat.
Why are the right side wires to the glow plugs such a small in gauge???
Was it because Teflon wire is very expensive??? (like a couple dollars per foot, that much more for larger gauges?)
BTW, the repair of the damaged harness followed the manual, the #2 cylinder now
has a 10 gauge wire between the fusable link and the weather pack connector.
In reality, I could have used 14 gauge instead, but I had the 10 gauge wire handy.
As a note, the general guide line for fusable links is two wire sizes smaller
than the main circuit.
Worn spot: (from #2 cylinder)
Caused: (Melted insulation and a burn out in the main harness, not the fusable link)
Right side of the Glow Plug Harness (replacing the fusable link)
Left side of the Glow Plug Harness
