I think my glow plugs are not glowing.
Unless I plug in the block heater all night and day making the engine about 110 degrees, I can't get the engine started. If I get it started and drive, it's hard to start after sitting a while.
The glow plug light comes on.
There's a click.
It doesn't matter if I use my manual switch, there's still a click and the light comes on.
All the wires to the plugs (except that rear right one which is hard to reach so I didn't bother) measure 3.5 ohms to ground (negative terminal of battery).
The plugs have infinite resistance to ground.
I pulled one out and there's no continuity between the tab and the tip (infinite resistance).
I noticed between a wire and its plug, there was 0.03 volts when using the manual switch and 0.11 when turned on by the relay/controller.
The batteries drained almost a volt within a week or two of sitting (no driving).
I charged them in the truck overnight/day and they held enough charge to start the engine.
Maybe I need new batteries since they're about ten years old (Optima red top, drained a few times).
Maybe all the glow plugs are burnt inside (Wellmans, I believe they wouldn't do that).
Maybe there's a short from the wires to ground?
Batteries, plugs, short... does anyone have any ideas?
Thanks
1985 K10 6.2 Silverado
There's a click.
Thanks
