Glow plug relay connection bolt torque
SnowDrift
Ultra Conservative. ULTRA!
Central Ohio map dot
The 25 ft. lbs. from the torque spec. thread for this is for the electrical connections, correct? Not the hold down bolts. This sounds right, from when I did this recently, but couldn't quite remember and didn't want to strip the studs out.
I am not sure but there are a few people who tighten it too much and it ruins the relay.
I did not remember I put a torque wrench when I replaced mine a while back.
The ratchet never slowed down and they would just break
Umm, I hope you weren't using an air rachet! I just use my fingers around the head of my 3/8 drive rachet and use my thumb and pinky to twirl the rachet, not the handle, to reduce the torque applied. The free swinging mass of the handle on my 3/8 acts like a mini-impact. Compresses the split lock washer nicely, haven't broken a stud and haven't had a ring terminal loosen since I put a new GP relay on back in Jan 2011.
It's all a practice thing. I haven't turned wrenches for a few years, but was teaching my older boy last month how to use different styles of torque wrenches. When I tightened down with a ratchet and had him use a beam style to loosen it I questioned the tool, because I used to be crazy accurate. I ment to tighten to 75lbs, but went to 82. I did a "35" and it was 38 using another torque wrench to check it. Kills me, I was always within 1 pound all the way to 250 lbs range, and figuring the 1% standard error rule- that was something I showed off with to friends.
It's a practice thing like shooting or playing an instrument is. Torque wrenches recal rule is once a year, everytime dropped, or 1,000 cycles.
Want to get better- waste $15. Buy a harbor freight throw away one, compare it to your real one to make sure it's in spec, double check your monthly. Most HF are 5-6% off new and 10% off in a year I learned when working for a large company that only bought HF tools when I started there (into my 2nd year I had them off the crack). Use the HF one as a ratchet for everything you do for a while. You'll get the feel real soon. Then you have a loaner for the neighbor who doesn't understand to take care of stuff. You'll also learn why you don't buy accurate tools at HF.
On the air tool usage, I get close with them but worked with guys that had a feel for it and can be within a couple pounds everytime using impacts. Usually grey hair and very faded toolboxes was involved
