blizzardplowman
Crowd Control
OK, so due to lack of funds I ordered our toy hauler without a generator, but did pay for the gen prep package. Last year the toy fund was a little flush so I could spring for a 3600 watt, gas powered generac quite pac unit, only used it about 6 hours last season but did run it 15/20 minutes a month until storage time.
I got it out this Spring, checked the oil and added fresh gas to the tank and it fired on the second try, used it about 1/2 hour or so to top off the battery's on my spring trip (April) and just ran it once in Mid May. Went to run it tonight and thought, hey its hot lets give it a good run and use the AC in the trailer for 1/2 hour or so.
That's when my issue showed up, unit runs fine, powers up and gives me 124/125 volts, ran just the TV,lights, and fan for 10 minutes then turned on the air, worked great for 10 minutes, the bam no AC, and white ish smoke out of the exhaust along with a lugging sound from the motor....WTF? Shut everything down, re hooked up to shore power, ran the AC for 1/2 hour with no issue, humm. So I unhooked, restarted the genny and went all over again, TV/dish,all the lights (charger was on also) and the fan, 15 minutes, 123.8 volts nothing abnormal, on with the AC (123.2V), 15 minutes and all is well, ha must have been a fluke, good I'm ready for the 4Th. Went outside for one more walk around and bam, heard the AC cut out, motor lug, white smoke and the burnt rubber smell. Shut the genny off, plugged into shore power and the AC came right back on.
I am puzzled to say the least, any ideas? Unit has 7.8 hours, gas is from April 10Th, has seafoam in the tank and my quads and lawn mower run just fine on it, got most of it used out of the tank so I can put fresh in for the trip. The tank is my fuel station and has a pickup for the genny.
TIA
Bliz
TIA
Bliz
