- Staff
- #1
I did my annual maintenance yesterday by changing all oil and fuel filters and replacing the oil with Rotella T (12 quarts due to the FS2500 bypass oil filter) . I change my fluids only once a year due to all the extra filters. It is much easier to do the maintenance in June!
I also do a UOA just to back the fluids up and give me piece of mind on what is going on inside the awesome Duramax Engine. I replaced the OEM fuel filter with the Nicktane filter adapter and placed a CAT 1R0750 2 micron High Efficiency filter on it. I replaced my fuel pre-filter setup (CAT 1R0749) with a Baldwin, also a 2 micron High Efficiency filter. The #2 Diesel should stay nice and clean with two (2) 2 micron filters in line! The FS2500 bypass filter was also changed (Oil Dialysis).
Notice in the pictures that the CAT 1R0749 filter did such a good job, that the OEM filter was hardly used. That OEM filter is 2 years old, last replaced in 2008. Also notice the Allison spin on filter. I used a filter magnet on the outside, and as you can see, the magnet trapped a lot of metal on the inside of the can. (No need to worry, as I did save the magnet inside the Allison!
) If there was ever a doubt on using filter magnets, this is proof positive that they work, and work very well! I also used a filter mag on the stock oil filter. It also trapped some metal on the side of the can, just not as much.
I used filter mags on the OEM fuel filter but it really did not trap much.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The only thing I have left to do is grease the fittings. If I could only get my grease gun to work! :mad2:
Total Mileage 58151 as of 6-23-2010. Total mileage on the oil for this change is 13263.
