paintballrepins
I know this question has been asked many many times, but here goes again.
I'm putting gauges in my truck. I'm going with the standard Boost and EGT, I have to add oil pressure since I'm swapping the motor into my 97, using the old cluster. I'm not sure whether to use a 0-100 or 0-150 psi gauge, I know the stock gauge goes to 120 on the 03 donor. Just asking for some opinions on this one.
While I'm going at the whole deal I'm putting an Air Dog II 165 on as well. Since it has a pressure regulator, does anyone run a fuel pressure gauge, after the airdog/before the cp3, just to check up on the regulator. I understand its set at 10 psi for a reason, jw if anyone thinks its worth it to keep a visible check on it.
Thanks
Thanks
