millsroger
Two of the gauges I know are not reading properly. Here's a recap: Voltmeter reads low and so does the temp gauge. I get 14.1 on the battery terminals with it running, gauge shows about 12 volts--(1 1/2 notch below the 14 volt mark). Temp gauge reading about 175 degrees but the ECT sensor reads 220 ohms and per the chart that's 195 degrees. (To verify the IAT and ECT sensors I pulled them both and used a pan of water and a digital thermometer I 'borrowed' from my wife, they both read nearly identical and properly per the chart from 40 to boiling).
Wiring I can find only shows these sensors going to the ECM, can't find wiring to the panel. Have crawled all over this truck checking grounds--all good, unless I missed one.
I do not know about the oil pressure gauge. Fuel gauge is actually reading wrong at both ends of the scale, about 1/4 above F when full and it stops moving at the E mark with 5 gallons left in the 34 gallon tank---that may be a different issue.
