saratoga
Unpaid Help
Has anyone used the brake controller harness to wire up their gauges before?
Asking because I'm considering finally putting in a set of gauges and noticed that the brake controller harness has all the wires needed right there, even the lt. brown wire for illumination. If it works, this would eliminate the need for fuse taps or hacking into the factory harness to get power and lighting.
TIA!
TIA!
