Matt Bachand
Depends on the 6.5
Over the weekend swapping my primary fuel tank. (she leaks over 1/2 tank), must be at the seam.
62" Long 34 Gallon.
I bought a sender unit and straps also just in case, can return if not used.
Any tips/suggestions?
While I'm at it, i'm also replacing the Aux Transfer Lift Pump with the still working carter Lift Pump I had before I installed an AC Delco unit on primary circuit.
Tank, straps, Sender, cleaner, rags, PowerService all came to $300 at Napa. I will return the sender (80) and Straps (40) if I don't need.
62" Long 34 Gallon.
