duramaxdude
I want to remove my fuel tank to clean it out. Can I do it without taking my box of or do I have to take it of to get at it.
x2, undo the 2 straps and the fill hose. IIRC there is a ground also
Can I diconect the fuel lines from the tank while its still up or do I have to Lower it a little.
Empty fuel 1st even a little sloshing makes removal awkward if doing by yourself, PB-Blast the bolts for the straps makes life easier, you'll also want to PB-Blast the connecting fuel line fittings on top of the tank, get the correct metric wrenches, 18 & 16 mm I think, they won't slip off the fittings as easy
What does PB blast mean. Do you know how many lines are going into the tank? Also is the gas gauge wire a big proble. First time taking a tank of for me so i'm alittle nervous
