Alright. So I am in the middle of my 6.5 to 12v cummins swap. I have to wire up 12v constant (battery), ground (battery), & a 12v ignition wire. The first two are easy, just connect directly to the battery. The last one is where I'm stumped. The engine is out of the truck, & I'm trying to figure out wiring before hooking everthing back up.
Long story short, I need to know if the Fuel Sol fuse has constant power or if that is powered with the ignition? Thanks!
