I believe my sending unit is bad because my fuel gauge needle is interfering with my oil pressure gauge, it has been reading wrong for a long time. Well now I have some added incentive to fix it because it is leaking $4 per gallon diesel from what appears to be coming from where the lines connect to the tank. It seems that it only leaks when it's toward the fuller side because if I leave it sit it won't be leaking after several days, I just don't know how much is in it because the gauge don't work. Where is the best place to get the parts I need to fix it?
Thanks,
Bob
Thanks,
Bob
