Nessmuk
I've had an issue with popping off fuel return lines. I've tried two recommend sources for the braided type that does not need clamps, neither stayed on. I've also found the braided cover loosens at the ends.
What I did was push the cover back enough and put a new clamp on each end. Then I used shrink tube that has heat activated glue in it on each end behind the clamps. Using a lighter to shrink the tubing also fizzles the loose wrap off. It works and looks good. I buy the tubing on line from tem-co.
