fuel pump options
Which fuel pump to run on my new 6.2L TD?
  • Used Mechanical Fuel Pump
    Votes: 0 0.0%
  • Used Facet Elect Fuel Pump
    Votes: 0 0.0%
  • New Mechanical Fuel Pump
    Votes: 0 0.0%
  • New Elect Fuel Pump
    Votes: 3 100.0%
  • Total voters
    3
Mikey von
Burney, CA
needing to decide what to go with.
1) I can run the mechanical pump off my '89, which had the head gasket/hydro locked problem.
2) Run the electric which came off the K5 with cracked block. It work before block cracked. It is a Facet. I found these numbers on it (have no clue what they mean) -
e11*72/245*95/54*0536*00
3) New mechanical pump.
4) New electric pump.
I am trying to be good with my money. I have a turbo return fitting on my oil pan.
I would get a Walbro FRB-5 or 28 from Leroy at PMDcable.com if he has any.
That Facet you have might not be flow on fail and it may only be about 4psi. Although there are Facets for 6-8psi which would work, cylindrical, and yours is probably a square.
Well if you hook it up and it puts out 3-5psi throughout your acceleration its a good pump to use. Will need a fuel pressure gauge you can monitor, good to have any way you go.
That's about the same numbers as our stock pump. I would think it would be a little shy at wot especially with the motor that your using.
