CBCS
Country Boy Can Survive!!
Does anyone know where i can get an aftermarket fuel pressure regulator? Dealer wants 300 for the part and another 250 to put it on. Or will a PPE shim kit solve my problems?
Is the fuel pressure regulator and the relief valve the same thing. I found regulators online and napa and such but cant seem to find anything that says relief valve.
And what causes this, lack of pressure or too much? Mine idles along fine, then all of a sudden it will surge up, a real quick blast then back to normal. It used to only do it every so often, but it's pretty frequent now. Probably once every 30 seconds or so.The regulator is on the pump and generally either works fine or lopes/surges.
A simple shim will increase the relief valve dump point, but typically it's a flow deficiency that beats up on the valve so I might suggest adding some "push" on the fuel in the form of a lift pump.
