dka99burb
Is there a fuel pressure regulator built into the IP return?
Do verify fuel pressure with mech gauge.(best place for hookup is just before the IP inlet).
IP housing pressure is maintained with the inline pressure regulator located in the return nipple/fitting at the top front of the IP(not really known to fail)
I stand corrected, I hit the books what I considered to be a return check valve actually per the GM IP training manual does indeed serve as a pressure regulator.
Tim I knew you were coming back on that one...:agreed:
:hihi:
SSDiesel is the only guy that sells them.......I've NEVER seen one on any other vendors site/store/whatever.........Isn't it supposed to keep the prime in a extended/overnite/I havn't started my truck in a week condition.
But if it is really shot, I guess that week could be more like a few hours.
Nope,the regulator is not a checkvalve.
The fuel system is closed loop and don't requires the system to maintain pressure with engine off.
So what is the function of the regulator, just to maintain pressure to the IP while the engine is running......Or is their something else in the equation?
gloshift fuel pressure gauges suck, especially if you got the 100psi one, which wont read hardly below 10psi.
Engine bay looks great, with the FFM on the "Stilts," the OPS extension clamped down nice and neat, as well as the Fuel Pressure gauge(s), Hoses and Tee's all rigged and clamped.....Nice job! :thumbsup:
6 PSI at idle......Did you confirm what PSI was at WOT and cruising?
