ive got a 96 chev c2500 with a 6.5 and ive got a fuel leaking problem coming from under the intake manifold
anyone know where i can get a fuel system line diagram?
Fuel leaks in the valley are usually from dried fuel lines between the Fuel filter manager(FFM) and IP or water drain, or O rings on the FFM. The FFM is behind the Intake and the fuel lines run under the intake forward.
