jcool
#78 A(ACLU) FNG
I am curious what the diff between wix and acdelco fuel filters are. i can order a case of 6 wix for 23 dollars or 1 acdelco for 45..... ut:
OK, Where can you buy the AC/Delco Duramax fuel filters for $18-23 each? I'll need to buy some soon.Wix filters are good, but I prefer to use AC Delco, Baldwin, or Donaldson for fuel filters. All of the fuel filters, if purchased at the right place, can be purchased for $18-23 each. Even AC Delco.
yeah my bad I meant 23 a piece for the wix...
Wix filters are good, but I prefer to use AC Delco, Baldwin, or Danaldson for fuel filters. All of the fuel filters, if purchased at the right place, can be purchased for $18-23 each. Even AC Delco.
You've a good one here. BLineFilter has the Parker/Racor PFF5544 (3rd Generation) fuel filter for $18.10 each. This is the cheapest I have seen theses. (I understand that Racor makes the OEM filter for GM.)My last batch (6) I bought at GM Parts direct. Also try Blinefilters from Texas! There are a few others, but I seem to have my alzheimers acting up. Let me look deeper into this. Baldwins for $18, the AC Delcos are on the higher end due to the name! Parker/Racors for $18.10
blinefilter
Do you have any experience buying from BLineFilter?
Thnx.
