beerwolf
I have a ruff runing engine. Just started. Pulled the intake off and had a fuel leak on the IP, bottom line. Looked at the fuel lines and at the base of the fuel filter are two lines drain and out, drain line is hooked to IP and out line to T valve. Is this right? has been this way for two years.
It seems to have a miss in it, truck shakes going down the road. Could the fuel leak cause this as air is entering the system?
