Fuel filter question
Crankme69
Illinois the Corruption Capitol of USA
My filter was changed back now coming up on 20K miles ago. I'm not have any issues with it at all. On my 7.3 I always ran em until the filter DP light would start coming on, but in that I ran a bunch of chit mixes that I wouldn't dare attempt on the 6.5.
So 20K should I change it this time when I dump the oil? Does this have a DP light or just the water in fuel light?
TIA,
69
Before I put in my prefilter, I did mine every 6k miles, which was only 3 times. Now that I have the 12 micron before it, I might go twice that unless pressure suffers.
C69 the only way to KNOW if it needs to be changed is via a gauge to the IP looking for loss of lift pressure or installing a DP switch to monitor increased vac across the filter, I once got a bad load of fuel on a "just installed" filter <3K miles on it that robbed me of power,
A mileage driven change recommendation is just that, a recommendation as one can get some "bad fuel" at any time, 20K is just as good/bad as any interval you could pick.
Before adding the 10 mic Racor and vac switches I'd just run until performance got bad and carry a new spare with me at all times, once it started bucking under load or getting crappy acceleration I'd change the filter.
Now I carry same spare OEM plus spare Racor, if my high DP switch starts blinking my red LED on hard accel I know I'm needing to change it, last time I changed mine was 30K miles ago, I'm still going strong with those 30K filts.
Odd to me why GM did not put some device either electronic or a "pop up tell tale" indicator so one would know the filter was clogged.
Maybe you could go to a boneyard and find a old switch or go to part store and find it since you know what to look for in a part book, let us know the p/n because the one Racor sells is mega $$$ now for a simple vac switch
