bigchevy89
What is a good cheap fuel additive to run in my 93 6.5 3500? Is something like 2/stroke oil good to add into each tank?
219000 on mine replaced injectors at about 180000. Other than a vac pump delete and a turbomaster and glows everything else is stock. Oh and a cdr
I used to put 1:200 of 2-stroke, which translates to 16 oz. in 25 gallons, along with 1:400 of Power Service, which translates to 8 oz. in 25 gallons. Now I blend with wvo instead of the 2-stroke, and I'll still use either white bottle Power Service or another anti-gel additive along with it in the winter.
Marty, I just turned over 200,000 on mine. I've become convinced the miles mean very little on these 6.5's, if maintained and running well there is no reason to think you can't run another 50,000. How far is your trip home?
