check if the breather hose and cap is still open.
...be carefull using a prybar so you wont crack the housing.
pull the hose of the nipple at the axle,or remove the thingemedjingy(cap) on the other end(dr side of rad) and push some air trough the hose. :rolleyes5::smile5:How would one test this?
That would work as well,not every one has one though.
