FRC 10
ak diesel driver
6.5 driver
alaska
Installed my pump finally (old one died) fuel pressure went up considerably at idle. I let it idle in my shop to get the temp up, and pressure started at 10.5 and ended up at 12 after awhile. It helped my hard hot start I just recently started getting, but only a little.
I just read your sig line Les, I could almost weld with what amps your heating elements draw.:hihi:
Could you provide some photos of your intall. I bought one of these for Colby, but he has yet to install it. I know it will come down to me to get the thing installed.
uploadfromtaptalk1393902235689.jpguploadfromtaptalk1393902271767.jpghere ya go bent a scrap piece of 1/8" aluminum diamond plate I had laying around. Used leroys fittings, didn't get too carried away as I might possibly add a filter setup later.
Sent from my Studio 5.0s using Tapatalk
