6.5coalroller
So after getting my new head gaskets on with head studs and my hx 35 turbo my truck is still leaking coolant in the same exact spot!!! Drivers side towards the back leaking down around the oil filter. I degreased everything on that side and got it dry. Started her up and layed on my creeper under the truck shining a light everywhere trying to find where is was comin from. Ended up I found a little green on the bottom of the freeze plug (second from the back) it trickled down to the lip on of the oil pan and ran back to the oil filter and dripped down. So I prolly never even had a problem with my head gaskets. I couldn't find anything wrong with them when I took them off. But you live and learn and at least I found the problem and it's not real real serious jus that I prolly won't be able to fix it wit the motor in the truck. So i'm thinkin bout jus rebuildin it this spring and puttin lower compression pistons in it. That way i'll have a pretty much brand new engine when I head to college. Not sure how much all that would cost I know Northern Auto Parts sells a rebuild kit for 1100 bucks but if I went with the lower compression pistons there wouldn't be any sense in buying a stock set too thats included in the kit. Where can I get the 18:1 compression pistons???
