Rachet
Active Member
Asking for $3500.00 O.B.O Local pick up only.
This is a retired ambulance Road Rescue Box
Located in Camano, WA 98282
Unfortunately, my injury won't allow me to finish the project.
Low miles (117,000 actual miles)on a 6.5L Turbo Diesel which has an upgraded cooling system incl. new hoses-Water Pump Leroy Diesel Restrictor, reconditioned thermostat housing & new 195-degree thermostats also from Leroy Diesel, new HX35 turbo, EGT gauge(metric) & Boost Gauge(both gauges sensors installed. New shocks all around, 7 Brand new 235x85-16 AT Tires (7th is the spare) mounted on wheels that I reconditioned, Front sheet metal has been replaced with a more aero-dynamic 2000 Cadillac Escalade(I have the grille and park-turn signal lamps. All new A/C System(Compressor, Condenser, Evaporator, all hoses) but hasn't been charged yet. The engine runs great.
I think it needs rear brake work as it is hard to drive forward but drives in reverse ok. The 4L80E Auto Trans might need solenoids worked on although I did pull hard on the wiring and may need a new trans harness. It may need to be towed.
The interior of the ambulance box and the cab have been stripped out.
