I turn the 4 way flasher or turn signal on and the lights flash but dimly. When I turn on the headlights the flashers go off and the taillight and the side clearance lights (dually) and the clearance lights start flashing. With one turn signal on both taillights and all the clearance lights flash.
Could the BCM (Body Control Module) be the problem? I don't see anything obvious wrong with the wiring.
