knh208
I finally had a chance to go see my buddy at the stealership and hook up to the Tech 2 :smile5:. I felt it was really important to get to it today, because I was sitting at a stop light when my engine revved, and then died. Restarted and ran flawlessly since, but made me wonder...
So, I have the following code:
P1216 - fuel solenoid response too slow :sad:
and in stored history:
P0724 - brake switch high input
P1214 - Injection Pump Timing Offset (TDC Offset = -0.09)
P1621 - EEPROM write error (can't remember the description 100%, assumed google would help me)
P1810 - TFP Valve Position Switch Circuit
Until today, my main concern was my cruise control, as found here: http://www.thetruckstop.us/forum/showthread.php?t=18837
With the stall today (first time since my chitty PMD cable came out 2 years ago) I am suddenly concerned that my DS4 is on its way out.
I tried to clear the codes, but received a communication error. I'm not sure if this is related to the P1621, but Google would suggest that error means a bad ECM.
So, given this list of codes, what do I actually have wrong? Presumably the P1216 means I should have plans to replace the pump. Is there anything else I need to look at while I'm at it?
Would the P1621 suggest that the ECM Bill sent me needs to be replaced?
Thanks in advance!
Thanks in advance!
