Danish Farmer
The new fuel filter element I installed this fall has started leaking around the plastic nut/spinner on the top of the FFM.
Got it tightend down until plastic meets the metal of the FFM, but it still leaks.
Is it common for a new filter element with a new o-ring to start leaking this early, or is it a symptom for something else thats going hay wire ? :rolleyes5:
Truck needs long cranking before starting, and figure this has to be solved before any more troubleshooting ?
regards Max
regards Max
