FFM heater, WIF sensor, Clear bowl and Hand priming
Burning oil
LeroyDiesel.com
Vendor
Houston
I got some new info and thought I would post it here first before it go's on the web site.
I have access to a new Wix FFM. It has the options listed in thread title. The way it will come is with the mount/base, and a 5 or 30 micron filter w/drain.
The heater, WIF sensor, Clear bowl and Hand primer are options
Basic kit w/ 5 or 30 micron filter $70.
Heater element with harness and oring $75.
Clear cowl $50.
WIF sensor w/ dash light & harness $120.
Hand primer $40.
Forgot to say. You can run one of the two options at a time in the mount: they are Hand primer or the heater.
On the bottom of the filter you can run the WIF sensor or the clear bowl.
FYI you don't have to have any of the optional parts if you just want a universal filter and mount set up.
I believe that is the exact filter settup that is used on the 6.5 equiped vans. They were factory mounted under the cab on the frame rail with a spash shield.
It is very simular, but I think different. GM probaly had some metric thread/special connections??
What size are the connections? What is the GPM flow rate? Could it be used to eliminate the junky stock fuel manager?
Its 80GPH For engines up to 350HP
Has 1/4 pipe ports.
It could be use as a replacement for the stock FFM. It can be mounted remotely or with some bracket/fab work mount in the stock FFM position.
Could also be a great alternative filter to a FTB mod?? HHMMM :thinkerg:
