Fan Removal
Rodd
Recruit
Antelope, CA
I am attempting to change my harmonic balancer and can't remember how to remove the fan. I did it when I replaced the h2o pump but that was 3 years ago. Nothing is coming up in the search field that helps. Maybe I'm doing it wrong. I'm typing fan removal and get nothing related.
Thanks for the help.
It's a spin on. it does have 4 bolts facing the engine but those only release the fan but not the clutch. There is a large nut that needs to turn counter clock wise and the h2o pump needs to be still but I can't remember how I did it last time. There are 4 holes on the h2o pully and I'm trying to fit something through them to grab on the engine but no luck.
You have either the spin on fan or there are 4 bolts on the backside closest to the engine.
I got it. It was a pain. I needed an extra hand. One turning the fan nut one way while the other holds and turns the pulley with a strap wrench the other.
