factory towing numbers (rant)
Detroit Dan
Epping NH
I just felt like venting again about this brand war between the light duty trucks, every maker is scrambling to post the highest numbers, as if that means they are going to sell more trucks because they have the "best in class" towing capacity. (anyone buying a truck to tow for real is probably not looking at half-tons anyway). Apparently they can make up whatever number they want and there is no regulation to it.
It first started annoying me when Toyota (the sticking gas pedal people) started running those ads with the trucks pulling 10,000lb trailers straight up and straight down, and stopping at the edge of cliffs and all sorts of annoying, unsafe foolishness. Now Ford is going toe to toe with them. Not sure where GM stands with their half-ton towing numbers, I stopped paying attention when I saw their front axle GVWR that restricts you to a Fisher-price snowplow.
So a co-worker just bought a brand new F150 crewcab lariat which came with an advertised tow rating of -are you ready for this?-11,300 lbs. Are you fricking kidding me? In 2004 my 1500 crewcab Chevy has a 7400lb tow rating, so how did they get these number so fantastically high? I've towed that much with my diesel dually 3500, and it works hard to get it up hills. Course I don't have the horsepower numbers, but I've got torque, I've got HD suspension and brakes, heck I've got twice as many lugnuts. I moved my 11,000 gvwr camper (8500 dry weight) around the yard once with the 1500, 295hp didn't want to move it, and without a weight distributing hitch the rearend was flattened right out.
Of course the half tons can tow a heavy trailer. It's on wheels! And they come factory equipped with sway control and brake control, presumably so nitwits won't try to pull 11,300 without them. But does that mean they should? I for one am a little nervous about putting all these people behind the wheel of a half-ton, towing so far beyond what it's real capacity probably should be, especially when most of these truck buyers don't know anything at all about towing. I mean, for commercial purposes you need a CDL-A to tow over 10,000lbs, but we are going to encourage Joe whitecollar to do it on the weekend with his big bad half-ton? I'm tempted to invite my co-worker to try to pull my camper with his new F150, just to see what happens.
And don't even get me started on the factory horsepower ratings. I'll save that rant for another time.
my 07 3500 srw has a hitch thats only rated to tow 7500lbs....and it is a 2.5" receiver....def a load of crap....when buying a 1 ton I shouldn't have to need to spend extra money to upgrade the factory hitch
Most 1/2 ton owners don't look at the weight ratings or know about a WD hitch. F*k just getting them to cross the damn safety chains is rare! :scared1:
However we are in an age where technology allows the power train or other weak point to be improved to get these ratings.
Then enter the bean counters and I mean the ignorant folks at GM. The 2005+ 1/2 ton truck has reverted to the obsolete drum brakes in the rear. So has a foreign manufacturer of 1/2 tons. These drums should be left off for weight savings for all the good they don't do when doing things like say stopping! :mad2: To make matters worse they throw electric fans on the 1/2 ton pickups now. :sosp:
I can purge the coolant with the 25" cooling fan on a Duramax towing easy. So I agree on a 115 degree hot day in hell, er..., AZ pulling the hills loaded you will question the rating with a "AA" battery powered electric fan... Esp with the forever known GM cooling challenges of small radiators, non-existent stack sealing, and poor ram radiator airflow... Mobile 1's comment about 300 degree engine oil was that every 10 degrees it 1/2's the oil life. I guess when you are testing it in a snowbank in MI it can work. :snow2
I don't know about the F150, but the 09 Tundra I looked at has bigger rotors than whats on my 94 2500....... I don't know if that makes it better or not because I think in a towing application heat disapation (sp?) would be better than size ......
but then again ..... I don't know what the towing capacity is on my 94 6 lug 2500.... my 5'er weighs 6500 pounds (25' prowler bunkhouse) and my 97 F150 struggled with it. my 94 2500 tows it no problems...... I even used to tow the LandCruiser behind the 5er for a combined weight of about 12,000 pounds ....... I would not even think of trying that with a 1/2 ton....... I don't think it would be legal anyways......
I'd love to see some of the truck pull those weights on a sled as opposed to wheels. dead weight is a whole lot harder. I find it funny my truck is only rated to pull 7400lbs or so.
):h good one. I weigh about the same as a dually. mind you I've hit hills where yes it'll crawl, but it'll still make it. I don't feel so bad about using the slow lane.
if you are talking about the truck in your pic ....... thats because it weighs more than a pregnant Elephant.
Hey, I have almost the same truck! Mines a 4wd 454 auto, with the narrow corporate 14 bolt rear tucked under a fleetside bed. Also has a Dana 60 front with automatic hubs, which I had never even seen before, but I like it.
I'm sure both my long wheelbase 1 tons have a lower tow rating than the new Tundra or F150. Can't wait to see what these wonder-trucks look like when they hit 20 or 30 years old.
your assuming they'll still be running. LOL I wonder how well they'd do with a dead weight. i admit it would be interesting.
With both of the farms 02,03 Dmaxes we constanly gross over 40,000lbs. Highest ive gone across a scale at was 48,000lbs.
The trucks spend their whole life with the axle bottomed out on the frame.
They pull it just fine, i put a mild tow tune in them and they really pull hard.
They stop it plenty fine as well, we put more sets of brakes in than most peopl but they still handle it.
The trailer we use is a 34' gooseneck triaxle. We load it with up to 36 bales, when wet these bales can weigh over 1,000lbs. Thats a lot of weight on a 2500hd.
We also haul concrete blocks with them. between all of us weve made over 70 trips hauling 24,000lbs of concrete on the trailer, plus the empty weight of the truck and trailer which is 18,400lbs.
We are licensed as farm so our weight restriction is 36,000lbs.
Factory ratings mean nothing really, at least to me.
A pulling sled weighs around 40,000lbs. I pulled on my factory reciever a few times, then a Class V hitch that I twisted as well.
We have also pulled loaded 22' chopper boxes with our trucks all the time and loaded gravity boxes.
Rookie's Results
Gotta know how to handle it or you might wind up like this...
I gotta wonder where you guys find these pics. I've had trailers sway before(crosswind) but always kept control. a cool head is the biggest key.
cool head.....and knowing when you are hauling a big heavy trailer that you don't go 75 mph and try to take curves like a Lamborghini.
A good way to teach people that is to stuck them in a semi hauling a quArter full milk tanker, you learn how to drive smooth real quick or you'll be kissing the steering wheel, I learned quick.
I use to drive a 2 1/2 ton fish planting truck. The worst is when it's about 1/3 down. That's a lot of weight that sure likes to lean the wrong way at turns. No baffles inside either.
Or have some asshole cut you off when your pulling loaded triple wagons in from a remote field.
Ya but they don't slosh.
My cousin got twisted up in an intersection pulling double gravity boxes.
Sloshing sucks big-time. I took a load of tea concentrate (like 24 55 gallon drums) in my International 4900 box truck from Hamilton, Oh to Cartersville, ga and it was the hardest load ever. What really sucked is when you had to hit your brakes going uphill. If felt like I was going backwards.
Try having a 1,000 gallon wave nail the front and back of the tank, youll come home with brusises from hitting the steering wheel.
Our tank holds 6,500 galllons and is usually filled to the brim, but ive driven a tank that was a 1/4 full and thats when its the worst. Milk tanks cant have baffles.
