Fack! did I break something or bad IP, PMD, PCM, WTF..... please help
MSchillingii
Diesel in the veins
Festus MO
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). __truck starts and runs but gas pedal does nothing at all, truck just idles high then low eventually almost evens out but the pedal does nothing, and smokes like a freight train_____
- Year: _1996_____
- Truck model and class (ie: c2500) __c2500_______
- Automatic or Standard __auto________
- Mileage: (indicate miles or km) __unknown milage says 125 but spedo dont work(long back story can explain if helps but back speed sensor doesnt work)_______
- Replaced parts and mods (IP, PMD, chip/PCM, TM, injectors etc) _Relocated stock PMD with Heatsink from computer__________
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? ___f ___________
- Ambient outside temp: (indicate *C or *F) ___70-80_______
- What fuel are you using? (#1 Diesel, #2 Diesel, Bio, VO, WVO, etc) __#2 diesel_______
- What fuel additives are you using? __none_________
- Where are you located? ___st louis mo__________
- Air filter _cold air K&n cleaned last monthe________
- Fuel filter __Just now_______
- CDR Valve? _What?________
- Coolant – last flushed/replaced at ____unknown_________
- Oil – synthetic/regular, changed at ___2 months ago________
- Batteries – state of charge, (matched set) replaced at ____one brand new/ one unknown_________
- Battery cables and grounds (removed, cleaned and tightened): __yes____________
- Glow Plugs - how many miles on them? ___unknown______ What type? _____________
- Injectors - last changed at ___unknown____________
- What were you doing when it happened? ___ my burb had dead battery so while removing the brand new battery to put in my other truck while this one was running then the service throttle light came on the idleing when crazy up and down so i shut it off. been doing that ever since i cleared the codes from orileys there was a code for like pump timing and some others but i forgot to write down before i erased codes___________
- How was the truck running fine before this problem appeared? __i guess once and a while it would jolt on highway like the pedal was getting let off then jump back up ___________
- Has this problem ever happened before? ____NO___________________
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) _unknown___ And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? __yes_______
1b] Does the engine crank over? __yes______
1c] Are your batteries fully charged? _yes________
1d] Have you removed, cleaned, and tightened all battery connections? __yes______
1e] Does your Wait to Start light come on for a time? How long? _10 seconds sometimes off and on two - three times________
1f] Does your glow plug light come on? __doesnt have_______ For how long? _________
1g] Do you see smoke from the exhaust while cranking? What color? _not while cranking_______
1h] Does the Service Engine Light Glow during Start/bulb check? __dunno bulb is broken______
2a] Can you hear your lift pump working? __yes hear it clicking__________
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _yes________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? __yes_________
2d] Loosen an injector line and crank the engine - does fuel come out? _unknown________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___always________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) ____relocated stock next to air intake_______
3b] Condition of Extension harness (if used) Vendor or Homemade? __homemade from trailer wiring (14g wire)_______
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _unkown________
3d] PMD Make: ___stock________
3e] PMD Age: _____stock________
4] Stalling Issues
4a] Do you experience stalling only when hot? ____N/A________
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) ___N/A___
4c] Does pouring cool water over the IP seem to help with restarting? ____N/A_____
4d] Is stalling momentary (engine recovers)? _N/A________
4e] Does SES light come on when engine hiccups? __UNKNOWN_______
4f] Does cruise control quit working when engine hiccups? ___N/A________
4g] Does re-starting seem to reset engine, restoring cruise and power? _N/A________
4h] Changes to dash lights or instruments during stalling events? _____UNKNOWN______
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? ___UNKNOWN____
5b] Any bubbles or oil film in coolant overflow tank? _NO______
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? ____NO______
5d] Excessive white smoke from exhaust on cold start? ___NO______
5e] Excessive black smoke from exhaust under hard acceleration? __USUAL________
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? ___NO________
6b] Maximum boost under load? _____UNKNOWN_______
6c] Have you added a performance PCM (reflash) or Chip? _____NO/UNKNOWN_________
6d] Have you changed exhaust / downpipe / crossover? _____NO CAT OR MUFFLER STRAIT PIPE___________
6e] Wastegate – mechanical or vacuum (OEM)? ______OEM________
7a] Single or dual thermostats? ___UNKNOWN_________
7b] Have you replaced them lately? Manufacturer of replacements? __NO_______
7c] Have you pulled and cleaned Radiator and coolers lately? _____NO_______
7d] Have you replaced the fan clutch? Manufacturer of replacement? ___NO_____
7e] (winter) Have you tested your antifreeze? Good to what temp? _____NO_____
7f] (winter) Are you using a winter grille cover? __NO_________
_____SMOKES LIKE TRAIN WHEN JUMPING UP AND DOWN RPMS I BOUGHT ANOTHER THROTTLE PEDAL AND TRIED PLUG AND PLAY IT DID NO DIFFERENT. ____________________________
Any help would be GREAAAAAAT!
oh yeah i also posted this on FSC.
Good luck with that they are mostly gasser folks there.
From your description I would expect broken fuel solenoid armature in IP, with one of the previous symptoms before this with fishbite throttle on highway.
You said remote mounted FSD on computer heat sink, how big a sink, did you used thermal paste, where is the remote location, the FSD you moved was it ever operated on a IP.
IP is my suspicion, but replacing the FSD with a new one would be 1st step, if you have to go the IP route a new or reman IP without a FSD/PMD on it will be less expensive, you'll have a new never been under hood driver for primary and if it isn't found to be bad the one you are using now can be your glovebox insurance policy driver.
Oh maybe you problem is you are trying to use the GAS pedal, vs accelerator we use in Diesels :) yeah I know everbody is a comedian right ?
Welcome to the site some pretty savvy 6.5 guys & gals here I see join date in Jan but only 2 posts so your new guy bubble has offically been popped. :thumbsup:
Thanks for the welcome. Yeah I joined here when I got the truck then forgot about this site so I had to bookmaker now. Been a long member at fsc. And as for GAS pedal yeah I even say that in my semi, bad habbits hard to break lol. Ok what is fsd and pmg? I read lots of post yesterday and seen those but dont remember what those are. And can I rebuild the ip? I found a rebuild kit for 60. Also another thing it just started doing a few weeks now is if I would start the truck up some times it would just die after like 5 to ten seconds and do this a few times before it would stay running. I thought it was a dirty fuel filter so I changed it but dont know if these problems went toghter. Thanks fire help
opps i reread that so fsd and pmg is the same thing ok, the heat sink i used was as big as the pmd and as thick and it has a nice thin layer of thermo paste and i moved it into the hole in the fender where the stock air box would sit, i figured all the air getting sucked into the cold air would keep it cool and it was the stock pmd/fsd. is there a good way to test the pmd? i seen an article on here about using a dmm whould that show what? also my truck has always been a loud ip sounds like a rod knock i would hate when people would say "hey your truck rod knocking" and i say "shut up stupid!" lol
ok so i read the codes to day and b4 i started it i got a p1218 injection pump calibration circut then started it and got p1641 p0219 p1216. does that mean PMD/FSD? i bought a tested used one on ebay with a warranty today so even if not i got an extra,
Would have replied sooner but I'm on a big repair project for work and running the nightshift repair team to boot I'm going to be sporadic participant next 5 months, guys & gals here can/will help out
Well......I'd say get a replacement FSD (fuel solenoid driver) what it's function is when it gets relocated from the side of the IP where factory/stanadyne call it a PMD (pump mounted driver) Leroy (Burning Oil on site here) sells least expensive option and stands behind it, ebay folks not so well.
Even if it is not this (I suspect the IP) it would not hurt to have a new one remote mounted in any case, save one you have now for a spare.
All gnds clean ??? http://www.thetruckstop.us/forum/showthread.php?17457-Grounds-what-are-they-amp-where-are-they
Some stuff for you to read if not visited already http://www.thetruckstop.us/forum/showthread.php?11081-Acronyms-quot-What-you-talking-about-quot
More here:http://www.thetruckstop.us/forum/forumdisplay.php?218-6.2-and-6.5-Technical-Reference-Library
No such thing as tested but good if it's ever been operated under the hood it is suspect, only good for a get home spare IMO, even with warranty, who was the vendor Edam ???
Check out Edam around the 6.5 community mixed feelings with them within the community as a whole.
so today i tested my grounds all ohm'ed out 3 or less mostly 0's, cool at 5pm my new/used pmd/fsd arrived threw it in the truck started and ran perfect! thanks for the help
Put PMD outside the hood. All these argument on the fender near the air filter, etc. has been argued before.
Bottom line is that anywhere inside the hood is still hot.
Yes, you are correct that you get air but what about when engine is off after running.
The temp goes up when engine is shut off and heat does not recognize whether it is the IP or the air filter.
Hey neighbor, I agree with mounting the pmd/fsd outside the hood also. The front bumper seems to be the prime location, bottom lip behind plate holder. Gets plenty of fresh air and also protected somewhat from road grime. Mine has been there for months, No prob
