Since I now have a truck chassis... this is a whole different deal than the van (bus) from before. The sound of the engine is very different in the cab vs having just a dog house to dampen the noise.
The wastegate was not operational at first, but now I have it locked shut for the moment. I don't have a boost gauge or anything else to verify operation... but I don't *think* I'm building a whole lota boost.
There seems to be sound, almost like an exhaust leak maybe somewhere in the system. Anyone have a quick fire way of pin pointing that? Engine running seems to drown out any small leaky noises. I was thinking of using a shop vac blowing up the tail pipe to see if I could hear anything under hood.....
Clue number two is, with the wastegate locked shut, I went WOT, and never threw a code for over boost.
Clue number three is subjective of course... Is the turbo very noticeable in it's sound in the cab? I could very clearly hear the turbo in bus 1 with it only 12" away from my right foot. But this has that plastic tube thingy projecting out from the turbo inlet, etc.
Bus 1 had a soot trap that was "opened up" for full flow. This also greatly improved the turbo sound.
I noticed the difference tonight as opposed to the first test drive... less smoke on WOT. I had a little blast at the beginning, and shifting. The first test drive was a bit lethargic, and quite a bit of hazy black smoke (not belching of clouds).
So, am I just getting deaf on the turbo sound, and how to check for a leak?
