Anubis
Being fat sucks
anybody running an exhaust brake on their 6.5 turbo?
what you got?
what it cost?
where you get it?
what you got?
what it cost?
where you get it?
exhaust brakes don't work for the 6.5 unless you also have a TCC lock, OBD-IIs don't have this option
I thought the TCC mod was for OBD2.... huh well glad to know it is mine then that get the TCC mod.
can't you put a switch on your TCC to lock it up in any gear at any speed like I did on my Bronco?
TCC mod for OBD-2 is to buy the TorqLock from BD. Another three Franklins on top of the cost of the exhaust brake. I've had the TorqLock for about a year and it works if you manage it well but needs the exhaust brake that I haven't ponied-up for yet. You can easily get the tranny into limp mode then you have to pull over and cycle the ignition or if you have something like a ScanGaugeII you just clear the code. Not much hill holding with just TCC locked up and a 10k trailer on back with no exhaust brake but better than nothing.
negative on OBD2, its a OBD1 mod only.
I assume it acts like your mod on ur bronco, but I wouldn't know, as I'm OBD2.
my opinion has always been, brake jobs are cheaper than an engine.
Any kind of engine brake puts strain on the motor. I realize in HD applications, they are nessicary but my opinion has always been, brake jobs are cheaper than an engine. It would seem to me you are using the TCC in a way is wasn't designed to be used.JMO. Tranny big bucks
descending Eisenhower and Vail pass with out an EB gives me nightmares. guess I could drop the Xfer case in 4L..... would require the TCC mod and putting a toggle switch on the CAD........ but could be done.
what you got?
what it cost?
where you get it?
