Engine Studder
Big T
Fullerton, CA
Did a road trip from SoCal to Bridgeport to get some end of season fly fishing in on the East Walker. Felt engine studder or hiccup while going up Sherwin Grade. Truck actually stalled while driving around Mammoth, specifically while coasting on a downhill towards a stop light. Studder happened again during the trip while going down Sherwin grade. Ambient temp going up the grade was 40 to 50 F. EGT 1100 to 1200 (at peak), going down it was 50 to 60. Engine coolant temp 220 at peak. Check Engine Soon and Check Gauges lights flashed. Voltmeter dropped close to 12 and then recovered to 13.5 after restart and for the rest of the trip.
6.5 Engine Diagnostic Troubleshooting Checklist
Problem: Explain your problem in concise language (ie: Cranks but won’t fire). ____________________________
- Year: 1995
- Truck model and class (ie: c2500) K2500 Suburban 4x4
- Automatic
- Mileage: (indicate miles or km) 158,000 miles
- Replaced parts and mods New IP at 115,000 with FSD on Pump. Have second remote mounted FSD behind Driver's headlight, but not connected at the moment.
- Model: ‘S’ or ‘F’ engine, NA or Turbo, EGR? F
- Ambient outside temp: (indicate *C or *F) 40 to 50 (1st time)
- What fuel are you using? (#1 Diesel)
- What fuel additives are you using? None
- Where are you located? Fullerton
- Air filter 151,000
- Fuel filter 151,000
- CDR Valve? NEVER (what is this?)
- Coolant – last flushed/replaced at 147,000
- Oil – synthetic/regular, changed at Delo 400 15w40 at 155,000
- Batteries – state of charge, (matched set) replaced at August 2007
- Battery cables and grounds (removed, cleaned and tightened): August 2007
- Glow Plugs - how many miles on them? ORIGINAL What type? _____________
- Injectors - last changed at ORIGINAL. Did 640 miles on one tank of fuel during trip. This is consistent over life of the truck.
- What were you doing when it happened? Going up a grade. Have felt the studder a couple times before in the past 3 months going up grades, but never had a stall.
- How was the truck running fine before this problem appeared? Fine
- Has this problem ever happened before? No
- Describe any related factors that might be part of the problem. ______________
- Have you checked for DTC (Diagnostic Trouble Codes)? (Y.N) NO And? ________
Diagnostics:
1] Starting:
1a] Does the engine start? Yes
1b] Does the engine crank over? Yes
1c] Are your batteries fully charged? Yes
1d] Have you removed, cleaned, and tightened all battery connections? Not recently
1e] Does your Wait to Start light come on for a time? How long? Yes
1f] Does your glow plug light come on? Yes For how long? Standard
1g] Do you see smoke from the exhaust while cranking? What color? No
1h] Does the Service Engine Light Glow during Start/bulb check? No
2a] Can you hear your lift pump working? Yes
2b] Do you get a steady flow of fuel from the water drain (T-handle) ? _________
2c] Loosen the inlet line from the IP – is fuel coming out (Lift Pump on)? ___________
2d] Loosen an injector line and crank the engine - does fuel come out? _________
2e] Do you hear a vacuum (hiss) when you remove the fuel cap? ___________
3] PMD / IP Issues
3a] Location of PMD (on pump, on intake, remote mounted) On pump
3b] Condition of Extension harness (if used) Vendor or Homemade? _________
3c] Condition of grounds / ground wires to IP / PMD. Check Harness. _________
3d] PMD Make: Stanadyne
3e] PMD Age: 3 years
4] Stalling Issues
4a] Do you experience stalling only when hot? Yes
4b] Does it stall under particular circumstances? (ie hit bump, or on accel) Can't really say as it studdered going up and down grades. Stall only happened while coasting down hill.
4c] Does pouring cool water over the IP seem to help with restarting? Not necessary
4d] Is stalling momentary (engine recovers)? Yes
4e] Does SES light come on when engine hiccups? Check Engine and Check Gauges came on.
4f] Does cruise control quit working when engine hiccups? No
4g] Does re-starting seem to reset engine, restoring cruise and power? Yes
4h] Changes to dash lights or instruments during stalling events? Voltmeter dropped to 12. Check Engine and Check Gauges lights came on
5] Running Issues
5a] On cold start, does upper rad hose get hard before engine warms up? Did not check
5b] Any bubbles or oil film in coolant overflow tank? Never
5c] Any white slime on oil surfaces (dipstick, CDR, oil Fill cap)? Never
5d] Excessive white smoke from exhaust on cold start? No
5e] Excessive black smoke from exhaust under hard acceleration? No
6] Performance Issues
6a] Do you have gauges (boost, EGT) ? EGT, Boost, Tranny temp
6b] Maximum boost under load? Hit 10 psi sustained pulling Sherwin Grade
6c] Have you added a performance PCM (reflash) or Chip? No
6d] Have you changed exhaust / downpipe / crossover? 3" Banks Downpipe, Banks 3.5" cat back
6e] Wastegate – mechanical or vacuum (OEM)? OEM Vacuum. Recently replaced solenoid. Been working great.
7a] Single or dual thermostats? Dual
7b] Have you replaced them lately? Manufacturer of replacements? Robert Shaw 180_________
7c] Have you pulled and cleaned Radiator and coolers lately? No
7d] Have you replaced the fan clutch? Manufacturer of replacement? No
7e] (winter) Have you tested your antifreeze? Good to what temp? No
7f] (winter) Are you using a winter grille cover? No
The first thing I would do is remote mount a new PMD I would also check the lift pump/OPSU operation. To check lift pump/opsu while the engine is running open the drain valve t handle on the tstat housing you should get a steady flow of fuel from it.
PMD or FSD? Are these the same?
I have a remote mounted FSD on a heat sink with cable. It was disconnected when the new IP was installed along with new FSD on the IP. I figured it was a matter of time before problems started arising, then I'd reconnect the remote FSD. It's been awhile and I need to figure out how/where to reconnect the plug to the remoter FSD.
Alright, found the acronym reference list.
It's a tight squeeze but you can take a small stright bladed screwdriver and undo the harness on the ip and then a wire/coat hanger with a hook on it to fish it out where you can get to it.
Thanks AK. I was able to do as you described and now have it hooked up to my remote mounted FSD. I knew that it was in there, but it was tough to do in the dark.
BTW in 2007 we had this rig up in AK. Did just about every road on the AK map and got as far north as Gallbraith Lake on the North Slope. When we returned from the North Slope, I replaced my batteries in Fairbanks as the truck would not start. I hate those stock side post terminals and need to correct the stock bolts. Only one thing I hate more on this rig and that's the damn 4wd actuator. I have the motorized upgrade and that went out this weekend and came back on when I got home. I have the Posi Lok, but have held out on installing it.
Steve
Yep. While I'm waiting for parts to my boat diesel, the battery bolt mod is exactly what I'm going to work on next. I recall there is a post/thread on that mod on the other site.
Steve
