Mad Maxx
See, what had happened was...
I've Noticed Lately that my Engine seems kinda "Loose".
Whether it's Warmed Up or Cold, if I am Parked, and Rev to 1100 RPM's and Hold it there, the Engine will Shake enough to make the Cab Shake as well.
It's not Violent, or anything Crazy, it's just enough that if you're Sitting in the Cab, you can Feel it Wiggling / Shaking.
It'll go away if I Raise the RPM's, but it'll come back around 1800 RPM's.
I think this has something to do with a Weird Low Speed Shift I get as well. It Feels almost as if the Tranny is trying to Shift too Slow or Soft, and kinda "Tapers" itself into the Next Gear, rather than a Quick Clean Shift.
You think it could be a Torn Motor Mount?
Should I Order Up the M/A Motor Mounts?
