bison
I had some trouble with trailer lights not working.
I Replaced the bumper plug receptable but stupid me installed the brown wire(lights) on the wrong spade(to ground)(didn't know at the time)
As a result it kept popping the 20 amp fuse in the side panel.(park,interior and tail/trailer lights)
I ran out of 20 amp so intelligent me :rolleyes5: used a 30 amp fuse to try to find the obvious short.
Fuse popped again.
I finally found the mistake i made on the plugin
Buuut,..now the parklights stay on when i put a fuse in the fusebox the lightswitch on or off has no effect. Trailer unhooked.
Thinking that maybe the contacts in the lightswitch had froze together i replaced the switch with the spare lightswitch i have but it didn't solve the problem,..parklights stay on at all times unless i pull the fuse.
Question, is there a relay somewere that i don't know off that might be fried? ...or melted together wiring ???
this is on the 98.
Fuse popped again.
this is on the 98.
