Electric Fan Clutch
GM Guy
Manual Trans. 2WD Enthusiast
NW Kansas and SC Idaho
Does anybody know of an electric fan clutch for 6.5s? (or and other GM for that matter) i think that they would be good for fuel economy and noise.
Any feedback appreciated, thank you!
Not currently available for 6.5, best so far for us is a retuned mechanical clutch, with the 9 blade plastic fan, I ran a Kennedy clutch for years with steel fan, IMO it kicked in too early, I could watch 25 calculated Hp loss whern it kicked in on my scanner, I'm running a Heath fan clutch with plastic fan now, kicks in earlier than OEM, and later than a Kennedy, I have ample cooling on it, only pulls about 15 (calculated by scanner) Hp when it kicks in, I don't have data with plastic fan on a Kennedy clutch to see if that brings kick in Hp down with a lighter fan, but Kennedy clutch also oncekicked in tends to stay kicked in pulling load, heath seems to be more cycling than the Kennedy clutch allows for.
Yeah, there are a couple alternatives... there's the 20" metal one that Kennedy sells, the 21" DMax plastic fan, and there was a 20" 9-blade in the late 1999 and 2000 6.5TD 3500s as a stock item, if I recall correctly.
It seems to me that the stock 9-blade GM fan was a good price, too... not to mention you could probably find one at a wreckers (ahem.. environmentally-friendly automotive recycling centre)
