Chief915
915A Maint Tech
Not sure I have a problem here, just looking for your thoughts/opinions. I bought a Heath P-series chip a few days ago and installed it, everything is great with the chip. Got around to installing my EGT gauge tonight and went for a ride. I mounted the thermocouple in the exhaust elbow of my GM-8 turbo by the way.
First impressions are that the gauge must not be working quite right. I flogged the suburban full throttle, not towing anything, 6 or 7 times from 0-60 and 30 - 70 and about 450* - 475* F was all I could get on the EGT gauge. 13 - 15 psi boost, great power, etc. As soon as I let off the pedal, the temps drop to 300-325ish within 5 seconds or so.
I had read other peoples posts about the P-series chip, how "hot" of a tune it was, and that you could easily run into EGT problems when towing. I guess maybe I just built it up in my mind to expect to see higher temps while I was beating on the truck. I realize towing, or more load on the engine, will increase EGT's.... But I figure if I really have to work at it to get to 450* - 475* while it's empty, towing shouldn't be too much of a problem either.
Does these temps seem fairly normal or is my new gauge suspect? I am happy to see low EGT's, but at the same time I am curious of how accurate they are..... I tried to call Bill to see if these temps are to be expected, but they were already closed for the day.
