trotorx2
I've got a 5th wheel that supposed to weigh 11k empty. What is the highest sustaned EGT's I can run without causing damage to the engine? I've seen almost 1200 going over overpasses and a little higher going over bridges. It is flat here along the gulf coast but I plan on trips north thru Arkansas which has some pretty good climbs.
I expect that with some water and my 2 motorcycles it will weigh around 13k.
